can someone tell me what is the difference between VideoCD (NTSC).mcf , VideoCD (NTSCFilm).mcf and VideoCD (PAL).mcf and also which one is better quality?
Thread: different kinds of vcd
each of the templets you listed is used for a certin kind of avi file.
its not about qulity its about differnces (pal,ntsc,ntscfilm).
each of them has a different specification, and you need to
choose the right one for your video.
look here
http://www.dvdrhelp.com/vcdHELL AINT A BAD PLACE TO BE
?? you mean .avi as source file???Originally Posted by Heavensent
the source file can be almost anything....most likely with DVD rips, it would be from a frameserver, such as DVD2AVI's .d2v project file.
anywayz,
@umair...the various templates are what you want your OUTPUT VIDEO to be...
for PAL vs. NTSC....it depends on the TV you're gonna watch it on...
if you have PAL TV, then you need to make your output PAL.
if you have NTSC TV, you need to make your output NTSC.
and yes...there is a quality different between the 2 NTSC templates...
standard NTSC....this is if the source is INTERLACED (i.e. non-progressive)..... here, your output will be 29.97 fps and interlaced....
for NTSCFILM, this is if the source is non-interlaced, progressive, FILM. here, your output will be 23.976 fps + 3:2 pulldown (to make the video played back as 29.97 fps) and not interlaced
if your source qualifies for NTSCFILM, i would suggest you use it since there are less frames per second to encode for (i.e. 23.976 fps vs. 29.97 fps), each frame will get a greater share of the bitrate and hence, HIGHER VIDEO QUALITY.... however, this only works if your source is non-interlaced, progressive, FILM.
you are right poopyhead...
i just asumed he is trying to convert an avi.
it can be any kind of video file.HELL AINT A BAD PLACE TO BE
Is there 2 kinds of AVI extensions?
By jbitakis in forum Video ConversionReplies: 7Last Post: 24th Nov 2011, 11:32 -
What software do they use to make these kinds of videos?
By kite88 in forum Newbie / General discussionsReplies: 10Last Post: 10th May 2010, 01:16 -
I'm confused by different kinds of the same disc ID
By JohnnyBob in forum MediaReplies: 7Last Post: 9th Feb 2010, 17:50 -
Question about 2 different kinds of proxies
By jimdagys in forum ComputerReplies: 7Last Post: 28th Apr 2009, 04:53 -
help, anybody knows any kinds of software that can do fax on the pc
By flowerhorn in forum Newbie / General discussionsReplies: 7Last Post: 13th Oct 2008, 20:51
Statistics
Newest guides
Latest tool updates
New media comments
