VideoHelp.com Forum
  1. im trying to upload videos from my DV camera to my pc by connecting it to the firewire (1394) port on my Audigy card, nothing happens when i connect it to the port (like in USB it would just recognize a new device being plugged in). is there a way to activate the firewire port or what should i do?
  2. Member shoozleboy's Avatar
    if the sound card is functioning properly and your system recognizes the firewire port, then your camera would be recognized by a plug and play OS... like Windows XP.
    I notice that my camera is only recognized when I have the power turned on to it. Do you have your camera turned on when you plug it in or after you plug it in?
    What OS do you have? What kind of camera do you have?
    I assume that you have software to capture the video with, yes? Some of the capture software out there will allow you to control most DV cameras through the software itself, but the camera has to be turned on (I have to have my Sony set to the VTR setting on the power switch).
  3. xp got moviemaker
    make sure the camera is in video mode not record
  4. thanks guys, it recognized it now. ill try to upload it through Adobe Premiere, does anyone know how to do this (the camera has to be in viewing mode, but do i have to rewind the tape to the beginning, does it have to be playing? or is it self explanatory?) thanks
  5. Member shoozleboy's Avatar
    I'm not all that familiar with Premiere, but it being a high end video product from Adobe, I imagine that you should be able to control the playback/rewind/fast forward commands from within Premiere's capture mode.
    If not, then yes, you will have to rewind the tape through the controls on the camera first.
  1. Replies: 4
    Last Post: 5th Jun 2008, 15:07
  2. Best way to upload 16:9 video to Youtube?
    By alegator in forum Newbie / General discussions
    Last Post: 10th Oct 2007, 21:50
  3. Problem with connecting Samsung miniDV to PC thru 1394 port ?
    By vu9300 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 25th Sep 2007, 01:40
  4. Replies: 1
    Last Post: 20th Jun 2007, 02:45
  5. is the IEEE 1394 Adapter port necessary...
    By roochie in forum Media
    Last Post: 15th May 2007, 19:03
