VideoHelp.com Forum
  1. I recently purchased a Liteon 2001, and have been unable to upgrade the firmware. I've downloaded the file 2001-0227.zip from Liteon's web site, unzipped the files and burned the file "liteon_v0227.nrg" to a blank cd per instructions (in fact I've burned about 6 different cds, and 1 dvd using different methods). When I put the cd in the Liteon 2001, the machine puts up a screen showing "Play Menu", but at the bottom it says "No files found!". I was able to obtain 2001-0224.zip, but got the same results. I'm using the latest version of Nero. The machine seems to play DVD's ok and recognizes jpegs. What can I do? Is the chip set defective?
  2. I don't use Nero however I will throw in my $0.02. Are you burning the CD as a data disc (I think that's the correct mode)? Are you burning the CD using UDF 1.02? If so try the other UDF mode or vice versa.
  3. You should select burn image file not data file.
  4. In Nero 6 (the lastest version for download off their site) go to:
    Recoder
    Burn Image
    Select your .nrg file and then it will do the rest for you.
  5. Thanks to those who replied to my problem. You were right on. I disregarded the instructions and burned the file as an image, it automatically expanded and burned all the proper files on the CD. I put the CD in the machine and sat back while it did everything by itself. It pays to have the right connections.
  1. liteon hbs112 firmware
    By davechubb in forum Blu-ray Ripping
    Last Post: 5th Feb 2012, 12:19
  2. 2001-2010 my capture cards - comparison screenshots
    By vaporeon800 in forum Capturing
    Last Post: 7th Dec 2011, 18:58
  3. replacing a DVD burner on my polaroid 2001
    By majel in forum DVD & Blu-ray Recorders
    Last Post: 9th Aug 2010, 16:04
  4. Change to Gateway/Liteon firmware
    By knights89 in forum DVD & Blu-ray Recorders
    Last Post: 26th Dec 2009, 15:32
  5. New site with codec comparisons going back to 2001
    By Tab in forum Latest Video News
    Last Post: 1st Nov 2008, 10:32
