VideoHelp.com Forum
  1. havent seen results but if its like the Casio cw50 then it only prints in single colour only.
    There is a full colour inkjet printer Epson 900/950/960 but unfortunately its NOT available in Australia.
    I am waiting for a reasonably priced cd/dvd printer to be relaeased in Aust. so I can stop using sticky labels.
  2. Downer,
    I have one.
    Pros:
    - Very easy to use.
    - Print quality is very good considering.
    Cons:
    - Media is expensive (3 pack is approximately $24). Each pack Will print upto 40 DVD/CDs if you only print in one area as opposed to two areas.
    - Only one color can be printed at a time.
    I use it instead of a sharpie. I only print one area and that allows me to print two lines of text (movie title and any other text). The results look great on the silver sided media I use. Do not purchase if you want to have fancy graphics - get an Epson 960 and appropriate printable media.
    Good luck!
    Yeah, I am planning on getting one of those TDK thermal printers soon (I don't see the Casio brand for sale here). All I need it for is basic text labelling of discs. A printer that will do the full disc surface is just overkill for me, so spending £70 on one of these little jobbies will do me fine rightly. And the refills are £5 each ... a bit cheaper than cartridges for the Epson!
  4. Member Nolonemo's Avatar
    BTW, you can get the Casios for around $90 shipped in the U.S. Do a froogle.com search on Casio CW-50.
    They do work great if all you want to do is put a plain black title on your disk.
  5. Greetings Supreme2k's Avatar
    Here's a sample of what you can do:
    This sample is from the Casio CW-50 (around US$80-90)
  6. I needed a new printer anyway so I bought the Epson 900 which also does a very nice job of printing to printable CD/DVDR.
  1. Inkjet -vs- Thermal
    By Nator in forum Computer
    Last Post: 19th Mar 2012, 07:08
  2. Writing on Thermal DVD-r's?
    By videobread in forum Media
    Last Post: 8th Aug 2009, 12:15
  3. Printers for Putting a Label Directly on a DVD Surface
    By solarblast in forum Newbie / General discussions
    Last Post: 4th Jul 2009, 20:04
  4. Dvd printers Dymo
    By ultraman36 in forum Media
    Last Post: 20th Dec 2007, 17:07
