Hello.
I have a wedding video that I created and put to DVD.
I missed a 30 second scene.
I need to use Ulead DVD MFII to convert the VOBS back to the source MPEG 2. No problem.
Now, if I take the MPEG 2 and put in Vegas Video, add the 20 seconds(in the middle of course) and put out as MPEG 2 , SAME EXACT bitrate, will I lose quality ?
Is it better to send out as DV AVI which I normally do( but they are normally AVI;'s) and then use TMPG to re-encode ?
What I am trying to make sure is that by doing this, since I am not using AVI as the source, I dont degrade the other hour and 59 minutes of video for this stupid 20 seconds (which the customer must have)
THANKS !
hi,
i'm new to this, so i might be wrong, but since you don't change the bitrate, it is as if you're pasting the 3 parts together. there should be no recompression and therefore no loss in quality.greets,
honfrek
Lossless & Quick:
Step 1: Encode the clip you're adding in(clip a) using the exact same settings as the clip you're adding it too(clip b)
Step 2: Open the TMPGEnc MEPG Tools and select 'Merge & cut'
Step 3: Insert clip b(fully muxed) first and then set its end point to where you want clip a to go
Step 4: Add clip a(fully muxed)
Step 5: Add clip b again(fully muxed) and set the start point to where clip a would end in the final
Step 6: Hit RUN!
Best lossless for Windows 7?
By LSchafroth in forum Video ConversionReplies: 1Last Post: 24th Nov 2009, 22:32 -
Why can't anything do a lossless rotation?
By jimrooney in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2009, 01:04 -
Lossless Query
By anirban in forum AudioReplies: 11Last Post: 12th Oct 2008, 12:55 -
Is my rip lossless?
By NurEinTier in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 01:29 -
HD Camcorders not lossless?
By zeek543 in forum Camcorders (DV/HDV/AVCHD)Replies: 11Last Post: 13th May 2007, 21:23
Statistics
Newest guides
Latest tool updates
New media comments
