I have a Sony DVP-S530D DVD Player and I'm trying to change the region on the player from 1 to 2 or multi. I used the DVD Hack forum but havent had much luck. Im able to get into the system menu by pushing (Title- Clear- Power) but I cant make the chages there. I have a Phillips Pronto remote. Should I program the buttoms? If so where is the special IR's for theses buttoms?
Heres what I've tried so far but it never displays "Code"
- Turn On the unit with the remote controller
- Wait until "no disc" appears in the unit's display
- Press Pause, 3, 1, 4, 1, 5, 9
- The word "CODE" should appear in the display
- Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
- Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
- Put the player into Standby mode
- Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
- Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
- Press Audio and Return for auto-switching On
- Press Angle and Return for MacroVision On
- Press Subtitle and Return for MacroVision Off
Thank You for any help
Dave
Results 1 to 1 of 1
dvd code to multi region my sony dvp-ns39
By fcooper in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2010, 18:52 -
Region Code Assistance for Sony DVP-S530D
By Liz_Strange in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th Aug 2009, 19:07 -
Region code on Sony DVP- NS315?
By LilMac in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Aug 2009, 10:16 -
region code assistance with the sony dvp-ns700h DVD PLAYER
By stressed_with_sony in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jun 2009, 01:06 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 04:34
