VideoHelp.com Forum
    I've got a 730MB movie that I can't fit on a CD.
    Yes, I know 700MB CD can hold more (have saved dozens of other 700+ movie files), but this file won't save.
    Have also tried overburning with Nero, but unsuccessful on my drive.
    So, looking for simplest program to resize/reduce this AVI file. Is there an easy program that allows you to specify desired output size, without having to do a lot of manual specifications regarding file output?
    Thanks,
    Jeff
  2. What format is this movie in (avi, divx, mpeg, etc) and what are your trying to burn it as (data disc, vcd, svcd, etc). It makes a difference.
    However, resolution (re-sizing) has NO EFFECT on file size. Resolution effects video quaility only. Size is a matter of bitrate and runtime only.
    The easiest thing to do is cut off part of the movie (end credits?). Other wise you hav to re-encode at a lower bitrate to fit everything on one disc.
  3. Member dcsos's Avatar
    I think he meant RE-FILE-SIZE
    which we could help
    if as the poster asked, WHAT KIND OF FILE IS IT?
    If you don't know, download this, it'll tell you what kind of file you've got
    gspot codec appliance...
    http://www.headbands.com/gspot/download.html
    Thanks guys.
    It's a tight squeeze as it is I'm afraid - no credits or anything to cut. I'm sure it's intended to squeeze on to one disc, probably with overburn, but my system just won't do it.
    All I'm trying to do is save the AVI as an AVI on a data CD.
    Here's the specs on the file from G-Spot:
    VIDEO
    Four CC: div3
    Codec: DivX 3 Low-Motion
    Aspect: 640x272 (2.353:1)
    Frame/Sec 25.000 FPS
    Duration 02h02m17s
    AUDIO
    Encoding: MP3
    Avg Bitrate 96kb/s CBR
    Says it was done with VirtualDub build 11583.
    I'm pretty much a novice at video editing, so if there is a solution to get the file size down from the current 730MB to maybe 715MB (?) for a 700MB disc.
    Thanks,
    Jeff
    oops, left out: if there is a solution . . . I'd appreciate it!
  6. Member dcsos's Avatar
    Don't know how to chop a MPEG-4 AVI without re rendering it..
    Someone help us out!
  1. Resizing and joining two avi files and keeping file size down
    By wayc00lio in forum Newbie / General discussions
    Last Post: 16th Feb 2011, 10:18
  2. Avi resizing or creating quick dvd using avidemux
    By striker9 in forum Video Conversion
    Last Post: 2nd Nov 2010, 11:01
  3. DVD to AVI resizing problem
    By okman in forum DVD Ripping
    Last Post: 2nd Jan 2010, 00:46
  4. Convert 16:9 AVI to MP4 and resizing for mobile phone (?)
    By wldworld in forum Video Conversion
    Last Post: 6th Jul 2008, 23:48
  5. Replies: 7
    Last Post: 27th May 2007, 14:45
