I downloaded the newest version TMPGEnc 2.520.54.163 and DVD2AVI 1.77.4 and installed them into ONE sub-directory. DVD2AVI frameserved to .D2V and .AC3 files when inputting VOB files. Now TMPGEnc will not open/support these 2 files. Apparently, it will not accept .AC3 delay 14ms from DVD2AVI. Priority of audio was set to 3 with VFAPI tab.
I am newbie, Pls help.
Results 1 to 18 of 18
Sam Ontario
use ver 1.76 for dvd2avi
To the best of my knowledge TMPGenc doesn't accept ac3 files as audio source. Maybe the newer/newest verison/s do but not the what I've got.
Where can I find ver 1.76?Originally Posted by pharlapSam Ontario
Pls help where to obtain DVD2AVI version 1.76 or older! Thanks.
Sam Ontario
With the newest version of DVD2AVI (ver. 1.77.4), both video (d2v) and audio (ac3) cannot be opened in the latest version of TMPGEnc.Originally Posted by FT Shark
With the version of DVD2AVI 1.77.3, d2v is accepted and ac3 is not accepted by TMPGEnc and the movie is capabable of encoded with video only.
I think the original soundtrack is DTS. How do I frameserve it to the version acceptable to TMPGEnc?Sam Ontario
Sam Ontario
Sam Ontario
Google will usually get ya what ya needOriginally Posted by Sam Ontario
here http://www.slunecnice.cz/product/DVD2AVI/
Don't bash something that does paticularly work for you. I love DVD2AVI. On my machine, it works. And when it does, it does beautifully, exactly doing what its supposed to do.Originally Posted by Sam Ontario
Keep up that language, you'll hear from the moderators.
i have been posting this for awhile now. i installed odio dekoda. after i check for and remove bad frames, i use the source audio and video in TMPGEnc, even if the audio is ac3. no a/v sync problems anymore.Originally Posted by Vejita-sama
pm me if you need more info
I had enough of DVD2AVI. I give up. Thanks for those who tried to help!
Sam Ontario
For the last time, you can't encoded using ac3 audio with TMPGEnc.
However, MPEG Tools will allow you to multiplex with ac3. Which means you will have to encode the video and then mux the ac3 after encoding the video.
Pls enlighten me how to do that. In fact, after frameserving with DVD2AVI 1.77.4, it created 1 .d2v file 4 ac3 files and 1 tds file. I can use .d2v file created with DVD2AVI 1.77.3 as video input to TMPGEnc but the rest of the audio files just would not support by TMPGEnc. Any idea how to do that. I know this is a very difficult movie.Originally Posted by FT SharkSam Ontario
Use TMPGEnc to encode the video only (use the d2v as the source). After you encode the video then use the mpeg tools to multiplex the mpg and the ac3 file togeather.
I created mpeg with d2v as source and used the mpeg tools to multiplex the mpeg video and the AC3 audio created by DVD2AVI 1.77.4, it said it does not accept Dolby Digital (AC3).Originally Posted by FT Shark
Maybe this movie is too dificult for TMPGEnc on audio files such as .tds and Dolby Digital .ac3.Sam Ontario
Instant play of Quicktime movies no longer work with Firefox 4.x
By jbaugh in forum MacReplies: 4Last Post: 28th May 2011, 04:39 -
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 17:27 -
multiAVCHD - subtitles no longer work
By bobo343 in forum Newbie / General discussionsReplies: 3Last Post: 8th Apr 2010, 08:58 -
SVCD2DVD used to work, no longer
By gddeluca in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 23rd Sep 2009, 10:45 -
DVD Players no longer work on tv?? Any ideas?
By -mm- in forum DVD & Blu-ray PlayersReplies: 4Last Post: 15th Nov 2008, 19:13
