VideoHelp.com Forum
    A lot of the sources i convert have macro-block problems, not major, but noticable. I mainly use Avisynth or Virtualdub fameserved to CCE (for DVD conversion), and I need a filter or Plugin that will either soften the picture (like Tmpgenc does) or maybe add a little grain or something to reduce the blocks. Any ideas? I've already tried the default plugins and filters, but I was hoping to find something better...
    convolution3d ? I use AVISynth and Im not sure what Macro-Block problems are, but convolution3d is good for running on poor image sources.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  3. Setting a soften or other filter to a degree where it masks macro-blocks would probably result in little discernable detail left in the picture. There is a threshold kind of phenomenon to macroblocks and maybe softening it a bit will get you below the trigger for the blockiness, but I wouldn't try to cover up macroblocks by filtering. Probably better to figure out why you are getting blocks in the first place. I would suggest giving us more details on what you are trying to do. VCD, SVCD, DVD, what size, resolution, bitrate, etc. The best guess I have at this point is high motion, or noisey (you mention poor sources, more detail here might help too) input file and a low bitrate output. Convolution 3d might help if the problem is a bad source, but a better source is proably a better option if the souce is bad enough to be causing serious macroblocks.
    Convolution3d made a difference, but man is it slow... CCE normally runs at around 0.80 on my system, but it slowed to 0.40 with C3D...
  5. Yep, any noise reduction filter is going to be VERY slow. If you can get a setting which reduces macroblocks, without compromising the detail of the pictures too much then it almost certainly means a source that isn't clean. I'd suggest first work on getting a cleaner source. If that isn't possible then you are stuck with something like Convolution 3d. That's what I use with avisynth. For VDub I use Flaxen VHS. It's no faster and not necessarily better, but the settings seem more intuitive to me and I THINK I end up doing a better job with it. I don't know of any noise reduction filters (temporal, spatial or combo) that do a good job and don't slow things down a lot. I mean if you think about what that kind of filter is doing, it's pretty obvious why it would take a lot of time.
  1. H.264 macroblock sizes
    By grinder_luck in forum Programming
    Last Post: 13th Jul 2011, 08:26
  2. H.264 Flexible Macroblock Ordering
    By krao in forum Programming
    Last Post: 2nd Dec 2009, 23:39
  3. AVC/h264 1080p mkv macroblock problem on sequence transition
    By djesteban in forum Blu-ray Ripping
    Last Post: 7th Oct 2008, 09:18
  4. Noise reduction
    By Geevim in forum Restoration
    Last Post: 5th Nov 2007, 06:23
  5. Video Noise Reduction ----> H E L P
    By wxyz in forum DVD Ripping
    Last Post: 21st Jun 2007, 19:22
