What is the best way to burn a dvd movie using nero.
ISO or ISO/UDF or UDF or DVD-VIDEO
Ive always been using ISO/UDF but is that the best?
James
I always use NERO EXPRESS and select DVD-VIDEO. Works fine.
I usually use DVD-Video. No problems yet. I do know if you want to distribute your own work on DVD, you should ISO-UDF 1.02, it is practically universal playability.
Hello.
Believe it or not, a LOT of DVD players don't conform to the DVD-Video disc standard.
Use, at least for NOW, UDF 1.02 - it's the most compatible at the moment.
- Gurm
I used to use the DVD-Video setting. worked on many players but a MAC. Used UDF/ISO (UDF 1.02), the iBook with AppleDVD now plays it wihtout a hitch.
Use UDF ver. 1.02, if that gives you problem then use ISO/UDF 1.02. A few players do not like just UDF, but in in general its a little more compatible with some systems.
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 09:44 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 20:37 -
Created DVD(UDF) in Nero, works on some computers, not all
By ir0n_ma1den in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2009, 21:51 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 13:10
