I have few queries, please help
1. I notice when I convert my captured avi file to DivX by DRDivX, this black border appears only on sides..... how to get rid of it???
2. Will there be any difference if i burn my VCD using direct captured avi file or using DivX file. Which will be better. DivX saves space on my hard disk.
3. I have adobe premier 6.0, Should I edit my video using original avi file or divx converted file.
Please help no matter how simple these questions are
Thread: Few DIV X queries
1) There should be plenty of post's about the borders, that should give you at least a hint.
2) Of course. With every conversion you do, the quality gets down because picture information gets lost.
Try to cap with a huffyuv codec (allmost lossless compression). If the filsize is still to much take mjpeg or divx with the highest quality settings your machine can handle. I'm not exactly sure wich is less worse
, butt i think divx beats mjpeg (ask an expert) :P
3) Edit the original. I gues you capture, then encode to divx to store it on harddisk and just make vcd with some of your movies.
In theory, for best quality, you should cap with a 'lossless' codec HUFFYUV end edit the movie for the final result i.e. VCD.
But in real life, when you dont know from the start which is gonna be a VCD someday and you store everything by default with divx on harddisk, i think it's not really a difference when to edit.
Hope it helpsKeep on capping it,
I'll keep on downloading it.
Video conversion queries
By AussieTuca in forum Video ConversionReplies: 3Last Post: 16th Aug 2011, 19:01 -
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 20:42 -
Some plasma TV queries: Panasonic G10A plasmas OK for SD?
By rossnroller in forum DVB / HDTVReplies: 14Last Post: 28th Jan 2010, 17:01 -
Anyone know SQL queries?
By sdsumike619 in forum ComputerReplies: 3Last Post: 16th Oct 2008, 20:37 -
Burn in subtitle in a AVI div-x film
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2007, 10:02
Statistics
Newest guides
Latest tool updates
New media comments
