hi i've been figuring out how to make vcd's for about a week now and i can make them work on my stand alone dvd player.
ive read the guides on here and what i do is use goldwave for the audio and then TMPGEN to encode then i burn using nero and my vcd's work fine.
but the guides said to use vcdeasy to burn but it takes 2 or 3 times longer than nero coz it always makes a bin and cue file.
can i stop it making files and just burn?
does author mean to put in chapters and stuff?
ive had a joint so i'm rambling what i mean is,
if i encode a movie to mpeg1 for vcd and just want to burn it should i just use nero and it's burned and works in 10 mins or should i use vcdeasy which creates files i dont want and crashes quite a lot?
many thanks and remember u too were a stoned newbie![]()
(well some of u not all of u, some might be anti cannabis ppl)
Thread: vcdeasy?
back and sober!
maybe i should of read how to get a reply first lol
ok i'll try to make it clearer
should i use vcdeasy to make cue and bin then use nero?
or should i use vcdeasy to burn?
would the quality be the same with nero or better with vcdeasy?
tu for any replies
As long as your burning program actually works, then the quality will be the same. That is, as long as it isn't screwing up somehow then just use whichever program works for you.Originally Posted by zak_swan"Art is making something out of nothing and selling it." - Frank Zappa
thanks ZippyP
can u tell me what are the advantages of using vcdeasy to author
rather than just burning mpeg file to vcd with nero?
zak_swan,Originally Posted by zak_swan
VCDEasy is little more complex than Nero but VCDEasy will allow you to create true chapters (entry points) and menus. Nero can't do that. Even if you do not wish to create chapters and menus, it is better to create the VCD in VCDEasy and build the bin/cue file.
You can later use Nero to burn ths bin/cue file as an image; or you could let VCDEasy to burn also.
Regards,*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
