VideoHelp.com Forum
  1. I want to add a black border around a Divx video of mine so that when I convert it to an MPEG1 for VCD my TV will cut off the border with the overscan and not my video. How can I do this?
  2. Interesting idea... Im not sure if it'll yield quality results, but nevertheless:
    Open your vid, goto Filters and Add 'resize'. For Width & Height select something a little less than 740x480. Make sure you keep the aspect ratio the same... so make sure 740/480 = NewWidth/NewHeight. For Filter Mode, do anything other than nearest neighbor, I choose Bicubic. Then check expand frame & letterbox image and put 740x480 for for the width/height there.
    As for the Interlace checkbox, I'm not sure. Id image that should be checked.
    Then probably frameserve to TMPEG.
    Good luck. Im curious if the video quality turns out any good.
  3. If you wanted to, you could skip the frameserve stuff and virtualdub altogether with TmpGENC. Just go into the settings and adjust the aspect ratio settings to "Center: Custom Aspect Ratio" and make your total video larger than the custom aspect ratio you specify. Just simplifies the process. Good luck.
  1. VirtualDub - fixing bad frames with blending and without re-encoding
    By spicediver10191 in forum Video Conversion
    Last Post: 11th Apr 2012, 08:15
  2. VirtualDub - Editing and Fixing Sound
    By bpatters69 in forum Editing
    Last Post: 26th Oct 2009, 12:33
  3. Overscan or something else?
    By agamid in forum Capturing
    Last Post: 2nd May 2008, 16:01
  4. Overscan, Fixing the problem without Editing the avi files?
    By Gabriel87 in forum Authoring (DVD)
    Last Post: 21st Nov 2007, 19:41
  5. Overscan
    By 1980sumthin in forum Newbie / General discussions
    Last Post: 8th Nov 2007, 01:23
