Hi,
I have captured my DV video with Adobe Premiere 6.0 and wound up with an .avi file.
Then I ran that through Main Concept (I can also use TMPGEnc) to get the Mpg file, which plays fine in Power DVD.
How can I burn this mpg to a dvd-r? I use RecordNow DX with Sony DRU500AX.
Do I need to create a VIDEO_TS folder with VTS files and IFO's like DVD2one and Dvdshrink do in order to burn it?
I don’t want any lose of quality in the video.
Thanks for any help.
Thread: Mpg to DVD burn?
Use a dvd authoring tool
http://www.dvdrhelp.com/guides.php?howtoselect=3;6
http://www.dvdrhelp.com/guides.php?howtoselect=3;24
http://www.dvdrhelp.com/tools#DVD%20Author
Ulead DVD Moviefactory, Neodvd and Tmpgenc DVD author are very easy tools but with limited features, only basic menus. If you want to create advanced menus and similiar try dvd-lab. If you have encoded to standard dvd mpeg they should not reencode the video, only author(make menus and the dvd file structure,vob and ifo files).
YES YOU NEED THE AUTHORING APPLICATION
this is what you're missing
From the simplist Authoring (Ifoedit, Ulead DVD Workshop)
to the flexible (TMPGDVD author, DVD LAb, DVD Architect)
to the best (Scenerist, Maestro, Creator)
like go here
http://www.dvdrhelp.com/author
Can I burn a .mpg file to a DVD
By robrpb in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 20:56 -
Burn mpg on DVD but keep 16:9 ratio
By tou in forum MacReplies: 9Last Post: 1st Sep 2010, 02:49 -
Cannot burn an mpg on a DVD
By costaseco in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2009, 03:15 -
Burn MPG file onto DVD
By geek2330 in forum Newbie / General discussionsReplies: 15Last Post: 2nd Oct 2007, 08:51 -
Burn mpg on DVD
By knowmyname_20 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2007, 19:31
Statistics
Newest guides
Latest tool updates
New media comments
