VideoHelp.com Forum
Thread: encoding movies
  1. I want to burn a movie to play on my DVD player. My DVD player plays vcd and xvcd but not svcd. What is the best way to encode a movie to give the best picture quality and can i get a movie to have good quality and still fit a 2 hour movie on two cds.
  2. Originally Posted by jordan456789
    1) well...since SVCD is still higher quality than xVCD, you could try the VCD header trick. this sometimes works in tricking the dvd player into thinking the SVCD is a VCD and be able to actually play it. works on certain players that can't handle SVCD.
    more info here: http://www.vcdeasy.org/modules.php?n...es&id=VcdTrick
    2) if that won't work...you have no choice but to go with xVCDs. first, look here for more info on your dvd player: http://www.dvdrhelp.com/dvdplayers
    you need to find out the max bitrate your dvd player supports for xVCD. xVCD basically takes a standard, compliant MPEG1 VCD and makes it non-standard by 1) increasing the bitrate so that it can fill up the entire CD-R(s) 2) increase the resolution 3) uses VBR, instead of that horrible CBR.
    3) good quality 2+ hr movie on 2 CD-Rs??? maybe...depends on what you consider as "good" quality. i personally can only stand SVCDs and DVD-Rs...., but you may not notice any quality difference if you have a smaller TV and/or the movie is a slow movie (i.e. no action, fast-moving scenes). this is because to fit a 2+ hour movie on 2 CD-Rs, you will need to use a bitrate of around 1.7 - 1.8 mbit/s. personally, i never encode below 2 mbit/s for SVCDs because of the decrease in quality, but again that depends on you, your TV, and the movie.
  1. Replies: 2
    Last Post: 25th Nov 2010, 20:28
  2. Best VirtualDub codec for encoding Hi8 movies
    By jranaudo in forum Video Conversion
    Last Post: 14th Jan 2010, 09:12
  3. Defining the MB in movies when encoding in GK
    By Fire Foxer in forum Editing
    Last Post: 5th Nov 2009, 15:53
  4. Help encoding 360 x 360 videos (spherical movies)
    By sapojow in forum Video Streaming
    Last Post: 1st Aug 2009, 19:23
  5. 1h40min movies became 50min movies after conversion
    By oediv in forum ffmpegX general discussion
    Last Post: 31st Jul 2007, 14:13
