Got the Sony DVP-NC600 5 disc changer a couple of days ago. It plays my VCDs and DVDs ok but it 'forgets' the resume play position after each disk change. Resume play only works as long as I do not select another disk.
According to the manual resume play should work as long as I don't open the tray or press the 'Load' button.
Does anyone know whether this is normal behavior or do I have to bring the player back to the store?
I don't know if that's the same model I have, but I did buy two 5 disc Sony changers a month ago -- I'll look at home at lunch if I remember to see what the model number is.
They do indeed remember the disk position as long as the disk is in the machine, no matter what other disks I play or where I stop. But there are settings to set for this: I don't remember if this is the default or not, but I do remember I went to the menu and selected this.
If it turns out I have the same model I'll see what my settings are and report back here to you."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
Sony DVP-SR750H wont play divx files.
By dupsko21 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 9th Mar 2012, 19:35 -
Sony DVP-NC665P - Cannot Play DVD's Consecutively Automatically
By searchlight in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Feb 2011, 00:21 -
Sony DVP-NC600 Multi-region question
By kc7gr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Apr 2008, 09:10 -
Multizone code for Sony DVP-NC600
By moamoa in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Feb 2008, 17:19 -
DVD9 cannot play on SONY DVP-NS55P
By techworld in forum DVD & Blu-ray PlayersReplies: 14Last Post: 11th Oct 2007, 02:15
Statistics
Newest guides
Latest tool updates
New media comments
