VideoHelp.com Forum
  1. I burned a movie yesterday and tested it today on my dvd player.
    It didn't work so I checked it on my computer. It says theres 708mb on cd but the cd folder is empty. I'm asuming it didn't finalize burning session.
    How do I fix this or finalize the cd?
  2. need more details...
    which program used to burn...
    what did you burn the movie as SVCD, xSVCD, VCD, xVCD, CVD....???
    what's your dvd player?
    if you made a SVCD/xSVCD, the movie should be in a folder called "MPEG2"
    if you made a VCD/xVCD, the movie should be in a folder called "MPEGAV"
  3. I burned a vcd on Nero.
    When I put the cd in my drive on my computer it says theres 702mb on disc, but when I open or explore cd theres nothing. No files at all?
  4. weird....could be that you didn't finalize the disc...
    in nero's VCD template under the "burn" tab, you should check the box next to "finalize disc"
    do you have winDVD/powerDVD installed. perhaps, you can try using those programs to play the VCD.
    try testing your VCD on someone else's computer and dvd player.
  1. Finalize DVD-R, is this possible?
    By chiyoaiki in forum DVD & Blu-ray Recorders
    Last Post: 11th Mar 2012, 15:17
  2. do I HAVE to finalize to rip to HD?
    By DirtBikeMike in forum DVD & Blu-ray Recorders
    Last Post: 26th Jan 2010, 10:22
  3. Can't finalize BD-RE?
    By DGenerateKane in forum Media
    Last Post: 23rd Sep 2009, 18:45
  4. Disk Finalize
    By arobertson1 in forum DVD & Blu-ray Recorders
    Last Post: 4th Sep 2008, 18:28
  5. finalize Help
    By whittyscosie in forum Newbie / General discussions
    Last Post: 24th Feb 2008, 13:27
