VideoHelp.com Forum
  1. Ok, I'm sure there is a better way to do what I'm trying here, but I feel lik I'm close here so I'd like to focus on where I'm at, not how I got here. Of course, if anyone needs that info to help me out I will provide it.
    Here goes,
    I started with 3 avi's of excellent quality. I did tons of processing and right now I'm sitting with ifo, vob, etc sitting in a directory ready to be burned. The problem is that these files are 6.61 GB. I knew I would be over DVD5 capacity, but I thought I could get around that using DVD2ONE.
    Side note here, I understand I could have lowered the bitrate, but I lowered to 5500 already. I didn't want to go any lower, so I figured I would go over capacity and use DVD2ONE to drop frames. I've used DVD2ONE many, many times and I can never tell a difference with the backed up DVD. Your suggestions are welcome here.
    Back to my problem - I went to drop frames using DVD2ONE, but it said it couldn't process the file. It has yet to be decrypted. Now, DVDDecryptor doesn't give the option of decrypting files already on my hard drive.
    Does anyone know of a tool out there that will allow me to decrypt files residing on my hard drive? Or am I missing an option in DVDDecryptor?
    Thanks in advance,
    Mick
    "If it ain't broke, break it and make it better."
  2. Member wulf109's Avatar
    Smartripper can rip from files already on your HD,it will decrypt as it rips to a new diretory. Open Smartripper,there's a small file icon in the upper left,that opens files on your HD.
  3. Member wulf109's Avatar
    Sorry that's the upper rifgt hand corner.
  4. OK, I installed SmartRipper and started decoding, but I got this message,
    No keys found in this encrypted file!
    What does this mean?
  5. Member wulf109's Avatar
    It's not encrypted,DVD2ONE will sometimes give a false encryption error. Try DVD Shrink 2.3,it's freeware and may work.
  1. Replies: 0
    Last Post: 8th Oct 2010, 19:40
  2. Replies: 9
    Last Post: 16th May 2010, 18:46
  3. Replies: 11
    Last Post: 17th Mar 2010, 13:42
  4. What are all these files in my external hard drive?
    By jyeh74 in forum Newbie / General discussions
    Last Post: 18th Jan 2010, 23:54
  5. getting files of an LG RH188H hard drive.
    By swarez in forum DVD & Blu-ray Recorders
    Last Post: 7th Apr 2009, 09:47
