VideoHelp.com Forum
  1. I have burned many bin files, but have recently come across two SVCD files (in a row) that are giving me problems. I am using Nero to burn the image. The bin files are showing 800+ megs. When I burn the image, Nero goes through all the motions, but the cd is blank. I allowed that for one file, but the next one did the same thing. Has anyone run across something like this? I would appreciate any help, as I have searched this forum and have not found anything similar.
    Thanks,
    Rick
    Are you 100% sure that it was not set to simulate?
    try burnatonce or vcdeasy to burn the bin/cue, I hear tons of horror stories about nero messing things up all the time.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  4. Member Treebeard's Avatar
    use cdmage to open the bin file and see what is in there(corrupt file?). u can even extract the mpg file and burn that as svcd if u wanted.
  5. try Fireburner at
    http://www.fireburner.com/
    "OO"
    P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
  6. Thanks for the great info - The app is not set to simulate. I think I will try to separate the file and burn it a as a SVCD.
  1. cue and bin files
    By natty in forum Newbie / General discussions
    Last Post: 21st Jun 2011, 15:25
  2. Having trouble with .bin/.cue files
    By UncleBose in forum Software Playing
    Last Post: 12th Jan 2008, 06:06
  3. cue,bin converting to dvd?
    By zziem in forum Newbie / General discussions
    Last Post: 7th Aug 2007, 10:36
  4. What files/settings do I need for bin/cue
    By Choppa in forum Authoring (VCD/SVCD)
    Last Post: 23rd Jun 2007, 21:29
  5. How to merge 2 cue/bin to one DVD
    By motleycool in forum Newbie / General discussions
    Last Post: 7th Jun 2007, 21:26
