Hi,
I have downloaded a mpg file using emule but it's taking ages to complete the last 50mb and so I decided to stop the d/ling.
I can play the partial mpg file but some parts are missing. I'm trying to convert to vcd format but I can't find a way to do it since nero reported error
tmpgenc hangs at the point where the part is missing while virtualdub and vcdgear can't fix the problem too
Is there any solution?
Thanks alot!
Thread: Emule partial mpg file problem
finish the download. patience is a virtue.
His name was MackemX
I doubt I can finish cause a few parts have been missing for ages .....
Parity files?
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
1.Wait till it comes on TV
2.Buy it
:P
Problem authoring mpg file with ffmpegx
By blue439 in forum ffmpegX general discussionReplies: 5Last Post: 14th Dec 2011, 13:23 -
A/V sync problem when remuxing (AverMedia mpg file)
By matomato13 in forum Video ConversionReplies: 8Last Post: 25th Mar 2011, 21:48 -
Why partial filtering mess up the rest of the file?
By tendra in forum EditingReplies: 2Last Post: 1st Nov 2009, 07:51 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
