hello everybody,
can any one tell me how to convert a real player file thatis .ram or .rm file to mpeg or mpg or dat .is there any free software to convert it and is there any software to join small mpeg files like i have many small small file which i want to join into one single file.please relpy me
Thread: about converting rm or ram file
i love formula1 racing.
This question has been asked alot and I give you the same answer that they gave me, it is not easy to convert rm to mpeg and probably not possible. If you look at the convert section in this website they suggest a product called tinra. I have tried it and it fails every time, it can only convert som rm's and not most. The best method at present that works is a screen capture program that captures the picture and sound as it is playing, but I have found that the quality is not so good, for me anyway. I have given up on trying to convert rm's maybe someone will come up with a program one day that will do it.
On the upside rms can be joined with real producer if the rm's are all of the same spec. Download the free producer from real and issue this line.
"C:\Program Files\Real\RealProducer\RMEditor.exe" -i "Movie1.rm" -i "Movie2.ram" -o "output.rm" they join OK if both are the same spec.
Good Luck.
Tfr file from PC to DVD Recorder via RAM disk
By barry_w2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2010, 09:47 -
converting .rm/ram files
By schnaarf in forum ffmpegX bugs and suggestionsReplies: 4Last Post: 15th Mar 2009, 15:19 -
Converting a .ram file to a .wave or an .mp3 file
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 17:17 -
Extracting .VRO file from DVD-RAM to pc for editing
By mattsz in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2007, 13:25 -
converting a ram (real video) file to mpeg problem
By Bamahusker in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 21:35
Statistics
Newest guides
Latest tool updates
New media comments
