VideoHelp.com Forum
  1. karol
    Guest
    After installing ffmpegX (i guess and hope correctly), i've tried to encode a movie I edited on iMovie. So I exported it on Quicktime, and made all the settings necessary in ffmpegX. But when i click encode, I receive a message from the terminal saying:
    karolskotnicki% pbpaste | sh
    Encoding started on Mon Jun 30 16:03:20 CEST 2003
    ## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
    and a document that I can't open appears on my desktop.
    Can it be a problem while installing the fonts necessary to ffmpegX ? Any idea ?
    Thanks for answering
    karol
  2. RoRe
    Guest
    Hi,
    I'm getting the same message when encoding QuickTimes to SVCD, but with a readable result. The pitty is, that the result is crunched because of another aspect ratio. Any tips to that problem are welcome.
    Thanks,
    Robert
  3. Hugo B.
    Guest
    Hi,
    I also receive that message whenever I try to encode a movie previously encoded in Quicktime.
    The kicker is that if I leave the terminal window open it seems that it actually is encoding anyways... Weird!
  4. Originally Posted by karol
    This is not an error, it is just a normal output from the Quicktime components invoked in the encoding process. The encoding is normally going on. You just have to wait until it is finished.
    This is normal. SVCD's do have a weird aspect ratio, but playing it on your television will not make the movie look weird.
    " Military intelligence is a contradiction in term."
    - Groucho Marx
  1. i cannot encode with ffmpegx
    By Se0r in forum ffmpegX general discussion
    Last Post: 24th Sep 2009, 12:38
  2. FFMPEGX won't encode!
    By Kalasin in forum ffmpegX general discussion
    Last Post: 26th Jul 2009, 11:02
  3. What encode does FFMPEGX use for FLV?
    By pieman1968 in forum ffmpegX general discussion
    Last Post: 3rd Apr 2009, 13:16
  4. encode a Keynote Quicktime movie to mpeg2 using ffmpegx possible?
    By mkoehler in forum ffmpegX general discussion
    Last Post: 23rd May 2008, 09:16
  5. trying to convert from quicktime to FLV using ffmpegX
    By gokes in forum Newbie / General discussions
    Last Post: 10th Jun 2007, 10:03
