VideoHelp.com Forum
  1. Santo
    Guest
    I just installed SVCD2DVD+. I canīt start, because I always get the error "Directory does not exist". It doesnīt mater, what directory I choose (it is definitly not a file!). Can anybody help me please?
    Santo
  2. you need to tell me a bit more about your installation process cause i can't help without
  3. boomies
    Guest
    It seems to be an upgrade related issue , though i am not sure which specific upgrade. After experiencing the same problem , I uninstalled my copy of (s)vcd2dvdmpg+ and then re-installed it , this time i didnt do the update from 1.0.1230.10831 . It works fine now without that " dir does not exist " error. Seems that when I did the upgrade I was at version 1.0.1271.35733 when i had that error come up .
  4. ok.. i leave this to chrissy
  5. yo dude i had probs with svcd2dvd+ but trust me its u cause it was me he he. when u install it make a new sub folder in ur svcd2dvd+ folder and call it besweat(not besweet) then download and extract besweat to that folder. then place the reg xml in the svcd2dvd+ folder and thats it
    now update it and it should work fine. also even though u have mpegs and they look like mpegs i found that they were'nt so use vcdgear, and select mpeg to mpeg just to make sure ok laters dude
    kinda new to this he he
  6. Santo
    Guest
    Hi,
    I installed the program via download. I unpacked the zip-file and startet the msi-installer. Then I installed besweet. With the first run of SVCD2DVD+ the program made an auto-update. Now itīs build 1.0.1271.35733. I just removed the program and made an new installation. But I canīt install without the auto-update (the program wonīt start without), so the error is still present.
    Santo
  7. Member ChrissyBoy's Avatar
    Are you saying that if you just start the application from the Start menu it doesn't launch - you get a "Directory doesn't exist" error dialog? Or are you saying that after you launch it and browse to a folder for your source, you get the error when you press start in the application? Have you tried right clicking on the folder to start the program?
    BTW: I just found a bug myself (it will be fixed in the next update). Starting SVCD2DVD on a folder which contains a hyphen "-" causes this issue ("Directory doesn't exist"). To workaround rename the folder so that it has no hyphens.
  8. Santo
    Guest
    Hi,
    thanks very much, this was the problem. After I renamned the directory, the program starts
    Santo
  1. Where to start? I'm a amateur photographer and I want to start out in video
    By James Wright in forum Newbie / General discussions
    Last Post: 17th Jan 2011, 17:58
  2. what is the ANY! folder/directory?
    By stackner in forum Blu-ray Ripping
    Last Post: 27th Feb 2010, 16:07
  3. Replies: 0
    Last Post: 13th Nov 2009, 11:47
  4. svcd2dvd doesn't start
    By mapache in forum SVCD2DVD & VOB2MPG
    Last Post: 1st Feb 2008, 08:10
  5. Replies: 7
    Last Post: 16th May 2007, 03:53
