VideoHelp.com Forum
  1. You can't and won't find the Hack on the official homepage
    http://www.dvdfab.com
    It allows processing straight from the DVD so you don't need to rip it first with DVDDecrypter, etc.
    DVDFAB (doesn't do transcoding) it's to either strip a main movie only two one dvd (if it'll fit) or split main movie over two DVD+Rs. Or it can "Copy Complete DVD" and split it over to two DVD+Rs like DVDXCopy or InterVideo DVDCopy does.
    You can download the DVDFAB hack from here.
    http://www.mrbass.org/dvdfab
    www.mrbass.org DVDShrink | DVD2DVD | DVDFAB | Mac
  2. This piece of software/freeware just keeps getting better. Who did the hack for it?
    -=[ JHMac ]=-
    Experience is something you don't get until just after you need it.
  3. uknown 'nuff said....basically don't ask ...it's irrevelant.
    Not sure what went wrong, but the first DVD I tried worked fine (Scooby Doo), but on the second I got a Can't Open file(00001000) Error, now I get this error with any DVD I try to rip??
    Any one else have this problem?
    Best Regards
    Amelia.
    BTW: I think I will register this software, it really is good!!
  5. http://www.dvdrhelp.com/forum/viewtopic.php?t=165212
    see my post about forceaspi1.7 there....give that a shot
    edit: yes your right....I put the wrong link...ok now it's corrected.
    glad you got it to work.
  6. mrbass,
    That link is to this page.
    Hi Mr Bass,
    I found the problem.
    For Scooby I set the output folder G:\Scooby\ and it worked
    For the second movie I set it to G:\TheOne\ and I got the error
    I set the out put folder back to G:\Scooby\ and it all works now. Looks like once you set the output folder you can't change it (only if you're ripping).
    In any case I can live with this problem
    Thanks MrBass, I will register later today.
    Best Regards
    Amelia
  1. DVDFab Media Player 1.0.0.1 beta has been released
    By Kerry56 in forum Software Playing
    Last Post: 25th Feb 2012, 10:26
  2. DVDFab 8.1.6.3
    By tarzan54 in forum DVD Ripping
    Last Post: 12th Feb 2012, 21:06
  3. DVDFab 8.1.3.8
    By Ally68 in forum DVD Ripping
    Last Post: 21st Dec 2011, 04:50
  4. Is DVDfab still the best?
    By jason in forum Newbie / General discussions
    Last Post: 14th Jun 2009, 07:40
  5. DVDFab
    By agtjones in forum Audio
    Last Post: 18th Feb 2009, 22:05
