VideoHelp.com Forum
  1. Hi all,
    I was hopping someone can help me.
    I have a wave file that has a high pitched "wheeeee" sound and I'm having trouble getting removing it. I've been trying to use cool edit pro, but I'm not very experienced with it. I've tried the hiss removal, noise removal, ect. I was thinking that the hiss seems like its a very high pitch. I was thinking maybe If I could cut off all freq. above a certain level that might work. But I don't know how to do this. I've tried, with no success.
    All help is greatly appreciated.
    Kevin
    go to syntrillium.com and get the noise reduction tutorial. the basics are this. open file. check noise reduction in cool edit. make a sample of the wheeze. close noise reduction. reoopen noise reduction and use the wheeze sample and apply to entire file. all wheeze will be removed. much better results than cutting your frequency.
  1. Replies: 238
    Last Post: 10th May 2012, 09:59
  2. converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
    By extent in forum Newbie / General discussions
    Last Post: 11th Jun 2010, 12:38
  3. $$$ for help removing high pitch "ssss" sound
    By paudieshea in forum Audio
    Last Post: 20th May 2010, 18:52
  4. REMOVE Phillips DVP-642 "angle" indicator
    By gumbico in forum DVD & Blu-ray Players
    Last Post: 28th Jun 2007, 12:55
  5. Replies: 2
    Last Post: 15th May 2007, 04:07
