Hi,
i have a home video 20 mins long in DV format. When i burn(Nero) it to VCD, Nero compresses it down to around 200 MB. Can you make Nero compress this 20-min video to 700MB instead of 200MB (in other words, make this 20-min video occupy the entire CD. Therefore, have better quality)?
If Nero can't do this? is there any trick or program can what i describe above?
my system:
P4 2.4ghz
WD 100 Gig
Abode Premiere 6.0
BusLink CD-RW
Thank you
Thread: Compress 20min DV to VCD
Dont use nero to encode VCD it is not very good. Use TMPGEnc to encode to VCD compliant mpeg and then nero to author and burn if you want.
VCD compliant mpeg is 1150kbps or approx 10MB/Min so 20 minutes will be 200MB this is not negotiable.
If you want better quality (firstly it will look much better at VCD using TMPGENc) then you can make an XVCD using a higher bitrate for mpeg1. Or make a SVCD mpeg2 (find out if your player will play these) this has a greater resolution and bitrate upto 2520kpbs
How to compress DV avi
By marti252 in forum Video ConversionReplies: 12Last Post: 7th Dec 2009, 02:12 -
vcd compress software
By akakiami in forum Authoring (VCD/SVCD)Replies: 12Last Post: 5th Sep 2008, 16:24 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 12:03 -
Premiere is taking >7hours vs. TMPGEnc only 20min???
By alegator in forum EditingReplies: 6Last Post: 11th Oct 2007, 10:38 -
how do you compress video
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 13:21
Statistics
Newest guides
Latest tool updates
New media comments
