What the f....... is happening whyyyyyyyyyyy...
wann burn a dvd-r today and suddenly i got this error
'Internal Target Failure'
what is this how can fix the problem
pioneer dvd 105
nero the latest
Results 1 to 24 of 24
Thread: Internal Target Failure
One topic is ENOUGH. And please wait a few days until you bump your topic.
???? and now
ANYBODY...Originally Posted by Baldrick
Tried other burning software?
INTERNAL TARGET ERROR is a
"SCSI SENSE CODE ERROR" of some sort
so do as BALDRICK suggested..
Something is keeping the current software from completing
its write cycle to the drive..
after installing new burning software, plese make sure there's not a packet writing component running from the previos package (or remove all portions of the malfunctioning app)
Make sure the IDE controller you are on for the Pioneer is on PIO mode only if using Win 2k3 Server or Win XP. That is what worked for me when I had the same problem. DMA mode doesn't work for me.
I was getting this error just about every time I burned. It stopped doing it when I flashed the firmware back to the orginal 1.21. The hacked 1.33(or is it 1.3?) was causing problems.
I was also getting calibration errors.
I'm still having problems with getting errors near the end of the discs, but I'm hoping this is a media problem
WHERE CAN I FIND THIS PIO MODEOriginally Posted by jtommyj
Right click on "My Computer". Left click on "Properties". Click on the "Hardware" tab at the top. Click on "Device Manager". Go down until you see the "IDE / ATA controllers". Click on the little "+" sign. Double click on whichever controller (primary or secondary) your DVD writer is connected to and under "Advanced Settings" you will see "Device 0" for master and "Device 1" for the slave. Whichever it is, change that device to 'PIO only".
I have the same error trying to erase a Maxell DVD-RW with my LG burner.
After trying everything I can imagine ( different O.S. , software, DMA on/off, master/slave, ...) the conclusion I achieved is....BAD MEDIA
Yes, I have seen bad media cause that error also, but maybe mistakenly I would hope the poster would have tried more than one disc before posting that it is a "problem".
Go down until you see the "IDE / ATA controllers..this what i seeOriginally Posted by jtommyj
primair ide
secundair ide
via bus master ide
no dvd-rw
what i have is dvd-/cd-rom-station
and i tried more then 1 dvd-r
You will not "see" any DVD-RW or any specific device. You will see the "Primair" and "Secundair" IDE controllers. You need to know which controller your DVD-RW is connected to to change that controller to PIO. Double click on the controller that the DVD-RW is on and go into "Advanced settings".Go down until you see the "IDE / ATA controllers..this what i see
primair ide
secundair ide
via bus master ide
no dvd-rw
So if you have the DVD-RW as a slave on the first IDE controller to your hard drive, that would be "Primair" controller, device 1. If you have it set up as the master on the "Secundair" IDE controller, it would be "Secundair", device 0. Follow my instructions carefully. I can't get any more specific because I don't know how you have your computer configured.
Thanks man i found itOriginally Posted by jtommyj
But still getting ther error
and i'm using a 4x dvd-r and 2x dvd-r
Not sure what to tell you at this point. Did you try a different "brand" of media and not just another disc ?
i got 3 type of discOriginally Posted by jtommyj
princo 2x works fine but is a bad media
princo 4x power calibartion
nanya 2x internal target failure
Are you using the latest firmware ?
Which is the nanya DVD-R media code? Maybe it's PRNCO too, wouldn't be strange. You need DVDInfo or similar to get it.
Originally Posted by Dj_Rainaldo
dont wannn take the risk by updatingOriginally Posted by jtommyj
cause i here a lot off bad thinks about updating
i got firware 1.30
Originally Posted by Lautaurus
nanya 2x =
00000000 00 42 00 00 01 40 C1 FD 9E D8 50 00 02 89 0E 13 .B...@....P.....
00000010 87 88 80 00 03 50 56 43 30 30 31 00 04 30 30 31 .....PVC001..001
00000020 20 20 20 00 05 88 80 00 00 00 01 00 00 00 00 00 .............
princo 4x =
00000000 00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 F7 0E 0B .l...@....R.....
00000010 77 88 70 00 03 50 52 49 4E 43 4F 00 04 00 00 00 w.p..PRINCO.....
00000020 00 00 00 00 05 AA A2 22 22 20 01 00 06 0B 0F 12 ......."" ......
princo 2x
00000000 00 42 00 00 01 40 C1 FD 9E D8 50 00 02 98 0C 13 .B...@....P.....
00000010 76 78 80 00 03 54 44 4B 47 30 32 00 04 30 30 30 vx...TDKG02..000
00000020 30 30 30 00 05 88 80 00 00 00 01 00 00 00 00 00 000.............
and agin the princo 2x is a bad media
before this a ad no probs with nANYA 2x or princo 4x
Ehh i just downloaded the lates versio of n3ro 6.0.0.11
and i burned 1 princo 4x
after that the error appears agian
Pioneer DVR-110D - Internal target failure
By tjax in forum DVD & Blu-ray RecordersReplies: 5Last Post: 27th Mar 2011, 17:41 -
Help please! Internal Target Error when burning to DVD
By kylina in forum Authoring (DVD)Replies: 9Last Post: 4th Apr 2010, 13:49 -
Target Bit Rates for HD
By Bman. in forum EditingReplies: 2Last Post: 2nd Oct 2009, 11:01 -
Internal Target Failure on Nero
By ChonasMan in forum Authoring (VCD/SVCD)Replies: 12Last Post: 10th Aug 2008, 19:45 -
What Target format
By yomamaho in forum MacReplies: 3Last Post: 9th Aug 2007, 19:44
