I have bought 4.7 GB DVD R+ & - Disk and Nero nor Windows XP seems to be able to use the disks...it says the drive is empty...and ideas??
Thread: DVD-R CAN'T READ DISKS
Is the disk blank or does it have data on it? If it's blank then windowsXP will not read it or for that matter recognize it.
If you've bought both + and - R, I take it you have a dual format writer ? Obvious maybe, but people do get caught out !
What writer are you using ?
Or, can you not read recordable media in a DVD-ROM drive ?
More info, please !
I bought + first because I didn't know there are two types....it is - but still it isn't recognised by NERO or XP. They are blank....HELP!!!
Yes, so what recorder are you using ?
Can you read pressed media in your recorder, or does it ignore absolutely everything ?
LITEON LVW-5045 cannot read DVD-R disks
By elfie-gow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jan 2011, 16:58 -
Difficult to read disks...HW or SW change more helpful?
By Golem in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2008, 00:41 -
Panasonic E100H won't read disks
By mfaust1071 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 22nd Dec 2008, 19:01 -
AOpen DUW1616/ARR doesn read DVD type disks
By phill in forum Authoring (DVD)Replies: 5Last Post: 9th Sep 2008, 19:46 -
DvD R9 burns disks ok but cant read them
By craftycelt in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2008, 17:56
