When I want to joing mpgs with TMPGenc in often leaves out the very end of most clips - why's that? Can that be fixed? (For examle if I join 3 clips that are 10 seconds long, it will join them as if they were a second shorter - the final movie won't be 30sec, but let's say 27s).
Than I tried to join mpgs with Adobe Premiere 6.0, but it seems that it doesn't support mpg files... is that it? A mpg with 25fps added to the timeline and than saved will look like it has lost A LOT of frames! That's why I always need to convert mpgs to avi with Virtual Dub first, that edit them in Premiere, and than convert the avi to mpg again with TMPGenc. But when it comes TMPGenc, look at the first paragraph.
If you don't know how do help me, at least tell me of any other good mpg joiners please.
THANKS!!!
get this program 100% works
http://www.boilsoft.com/
joins everything under the sun not just mpg, but avi, asf, wmv, qt!!
enjoy!
Did you use TMPGEnc for encoding the clips you are trying to join?Originally Posted by LovE-RicH
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Todgerme:
Hey thanks, I'll try that.
Silky:
yes, I did...
But what I described doesn't happen always... and only just cuts just a second or so. Not a big deal, but sometimes can be really annoying.
Very strange, hope you solve it man
Adobe Premiere problem ??
By 3thman in forum EditingReplies: 9Last Post: 1st Nov 2009, 17:23 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 14:16 -
adobe premiere 6.0 problem clip speeding up why?
By suomiaussie in forum EditingReplies: 5Last Post: 20th May 2008, 21:02 -
Adobe Premiere Pro 2 Problem
By mymuckaccount in forum Video ConversionReplies: 2Last Post: 20th May 2008, 15:17 -
Problem with audio in Adobe Premiere Elements
By marioman1234 in forum EditingReplies: 2Last Post: 28th May 2007, 12:45
