VideoHelp.com Forum
    I understand that DVD authoring can be tempermental. Using the Sony DRU500 ax with the latest firmware windows 98 will not burn memorex DVD-R(1X) it burns about 4 minutes of material I used the program DVD X press copy. Contacted Memorex Canada and threy reported someone else had the same problem. They gave me samples of different media. Burns DVD+R and DVD+RW(4).
    Has anyone experiences similar problems with Memorex.
    Everythimg works perfectly using TDK DVD-R(2) The obvious solution is to use TDK but it is strange the Memorex will not burn
    I have Sony DW-U10A (DRU 500 OEM), I've have never able to complete a burn on Memorex DVD-RW. You can't even format them after they have been in the drive. I now use DataSafe or Beall's
  3. I have used the Sony DRU500 AX and the DRU510A with Memorex DVD-R and have had no problems at all. I tried the RW discs and they don't seem to want to record anything. Try the -R discs.
    Kellygirl
    I apologize I did not make myself clear It will not burn
    Memorex DVD-R(1) It burns anywhere from 5 to 10 minutes on the disc and then stops. I took my sample into Memorex to day and gave it to the sales amanger.
    I really do not expect memorex to do anythinmg more.
    There are three other factors
    Windows 98
    Sony DRU 500 ax
    DVD x press copy
    These three items are not interacting propelywith the media
  1. sony dvd rw dru-190a problem
    By videodude1966 in forum DVD & Blu-ray Writers
    Last Post: 17th Apr 2010, 03:53
  2. Problem with Sony DVD RW DRU-830A
    By VOD0708 in forum DVD & Blu-ray Writers
    Last Post: 10th Jan 2010, 14:43
  3. old Memorex apology press release?
    By lordsmurf in forum Media
    Last Post: 9th Dec 2009, 13:30
  4. Sony DVD RW DRU-830A
    By bjswitz in forum DVD & Blu-ray Writers
    Last Post: 30th May 2007, 08:41
  5. Your Opinion of these blank DVD-R's; Sony / Maxwell / Memorex?
    By Sudden Impact in forum Newbie / General discussions
    Last Post: 11th May 2007, 15:30
