Some DVD players just can't play SVCD... but in this case and if you are lucky your DVD player may be able to play VCDs that use the "VCD-Header Trick". By changing the "Header" of a SVCD MPEG-2 video file into the one of a VCD2.0 MPEG-1 file and by using it as standard VCD2.0 file, you may be able to play MPEG-2 files with your home DVD player. http://www.vcdeasy.org/modules.php?n...es&id=VcdTrick
