Hi, I've been using VCDEasyfor a couple of months latley but i went to rip one of the bin files for a film so I could burn it as an SVCD and no problem, turns out it was the wrong bin file. So i tried to rip the correct file, and I got this error message....
[VCDxRip.exe]
GNU VCDImager 0.7.12
unexpected descriptor type, check the bytes sectors mode
I am using VDCEasy v1.1.5 and the only difference in the files was the name and size.
vcd-Idscr-2.bin - 457 MB (479,431,680 bytes) (will rip)
ctp-ident2.bin - 773 MB (810,990,768 bytes) (Will not rip)
The first file was only a sample of what the file should be as when it was an mpeg it was only 8 minutes long.
Any help about how to fix the error or what the byte sector mode is would be most appriciated.
Thanks, Miss Faith Vamp
Results 1 to 1 of 1
Pavtube - Byte Co[py
By charlie_brownuk in forum Blu-ray RippingReplies: 6Last Post: 26th Sep 2011, 09:04 -
ffmpegX gives me 0 byte flash file
By flim in forum ffmpegX general discussionReplies: 2Last Post: 9th Apr 2010, 13:12 -
HELP! FAVC 1.04- Why is it creating 0 byte iso's at times?
By spexwood in forum Video ConversionReplies: 7Last Post: 5th Dec 2007, 23:40 -
Convert Media Exactly to allow joining by byte manipulation alone.
By benshole in forum EditingReplies: 0Last Post: 22nd Nov 2007, 06:51 -
how to check which udma mode is supported by drive?
By cL0N31 in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Oct 2007, 23:19
