VideoHelp.com Forum
  1. After install and run the program. it says it can't find video codec. Any ideas would appreciate it.
  2. Member DJRumpy's Avatar
    You've answered your own question. You need to install the proper codec to decode/encode whatever it is your trying to convert. I would sugest you install an MPEG-2 codec. You'll also need whatever codec is required by your source file (Like Divx, XVid, etc). Look in the TOOLS\Codecs section. You should also get GSpot from the TOOLS section. It will report whatever codec your AVI uses, and whether or not you have the necessary codec installed.
    The MPEG-2 codec is usually installed by the DVD Player software (like WinDVD, or PowerDVD). You cannot encode/decode MPEG-2 without this codec.
    Impossible to see the future is. The Dark Side clouds everything...
  1. Replies: 13
    Last Post: 14th Jun 2011, 14:21
  2. DVD Players no longer work on tv?? Any ideas?
    By -mm- in forum DVD & Blu-ray Players
    Last Post: 15th Nov 2008, 19:13
  3. Replies: 6
    Last Post: 24th Sep 2008, 13:47
  4. Coby DVD7107 Help - The hack posted does not work!!! Any ideas?
    By Catenkristen in forum DVD & Blu-ray Recorders
    Last Post: 25th Jul 2008, 14:46
  5. Low quality AVI playback after formatting my computer, any ideas please?
    By CBR600 in forum Newbie / General discussions
    Last Post: 27th Jun 2007, 02:45
