  1. When setting up the PC-VCR timer with the Matrox G-400TV to my D drive which has 12GB spare the scheduler shows just 930.5MB available to D drive for a captured TV program.
    Does this refer to the maximum size of an MJPEG capture for one session?
    Miklos
  2. I don't think so. My Marvel G200 will capture 2GB a trunk for unlimited time (up to drive capacity).
    BTW, The highest MJPEG setting will yeild about 3MB/sec, so 930 MB would only give you slightly over 5 minutes.
    Might be something wrong in your settings?
  3. It wouldn't hurt to run Scan Disk on your drive--there might be an error that's causing its capacity to be reported wrong. I had that happen once.
  4. Thanks both for your comments. I have the recording set-up to highest capture quality which reads 1hr 8mins for 12GB. However the Video Timer still only gives 930MB for a time shifted program capture. I suppose it could be a faulty readout and the only way to test it is to try it out
    and see how far it will go!
  1. How to get the best from my Matrox Marvel G200
    By sidneysides in forum Capturing
    Last Post: 10th Jan 2003, 10:04
  2. Problem converting Mjpeg avi from Matrox Marvel
    By felix in forum Video Conversion
    Last Post: 7th Sep 2002, 00:00
  3. Best way to capture with my Matrox Marvel G200
    Last Post: 9th Jun 2002, 20:09
  4. Matrox Marvel G200 or Marvel G450?
    By Benn_Black in forum Capturing
    Last Post: 12th Apr 2002, 15:51
  5. Replies: 2
    Last Post: 4th Sep 2001, 22:41
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
