VideoHelp.com Forum
    I have a chance to get a WD hard drive with 8 MB buffer. I have a Tyan Dually system with a 20 GB HD for OS (Win XP Pro and Win 2K3 Server dual boot) a 45 GB IBM for conversion files and a 160 GB Maxtor for storage of DVD files. My set up has 1.5 GB registered PC-2100 and 2x AMD XP1900+ processors.
    Does anyone have any expereience or advice if the 8 MB buffer would speed up the AVI to DVD conversion using TMPGENC versus staying with a 2 MB buffer ?
    Maybe a little technical but just looking for someone who may ahve recently upgraded hard drives and has any input.
  2. Member lgh529's Avatar
    I could be wrong, but increasing the HD buffer will not increase the speed of MPEG encoding. MPEG encoding is more of a processor and RAM issue as opposed to a disk issue.
    I agree. I don't think it will help.
    It may help with video capture where you are getting occasional dropped frames, but unlikely to help with re-encoding as this is more CPU bound.
    The extra buffer is more likely to be noticeable for bursts of HD access, not for a constant stream.
    The glass is neither half-full, nor half-empty.
    It is simply twice as big as it needs to be.
    A larger cache on the HD is very unlikely to improve encoding speed because it will probably take longer to process a frame of video than to read it from the disk. A larger cache can sometimes hurt you when you capture. But for an application/system drive or a general data (not video stuff, smaller files) drive it can improve overall performance.
  1. MuxMan : Buffer Underflow
    By Bonie81 in forum Authoring (DVD)
    Last Post: 23rd Oct 2011, 15:38
  2. mp4 won't buffer...
    By jfharper in forum Video Conversion
    Last Post: 27th Sep 2011, 11:12
  3. YouTube Buffer Speed
    By gooberguy in forum Computer
    Last Post: 25th Feb 2010, 21:12
  4. Buffer Device question:
    By butt_crack in forum DVD Ripping
    Last Post: 5th Feb 2010, 11:35
  5. What is buffer size?
    By dzsoul in forum Newbie / General discussions
    Last Post: 6th Dec 2009, 09:04
