Ive got an mpeg 1 file which has a bitrate of 1300 kbps.
i want to convert it to an mpeg 2 file and burn as an svcd.
Im quite new to this vcd stuff but basically i want to do this
a)demultiplex the file to seperate audio and video
b)re-encode the video in tmgp
c)multiplex them back together
d)create the vcd.
Ive got stuck at part a) , using tmgp it wont demultiplex it properly, each file is only about a 1/5th of the whole video. Im not sure if this is because it has a padding stream. Ive tried using bbdemux but this doesnt work either. Ive also tried fixing the file using vcdgear but this wont work, in the log file it reports it has a 5412 sector size and attempts to give it the right sector size and also pad the file but it just splits it into about 30 seperate mpegs none of which are readable.
I know i could rencode both the audio and video at in tmpg but i dont want to lose audio quality.
Anybody got any suggestions on how i can get this file to demultiplex?
Running winxp
thx,
bri
Results 1 to 1 of 1
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 00:00 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 13:58 -
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 14:23 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 16:24 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 07:17
