Hi
I have a XVID which, towards the end of the file loses synch between audio and video by 1 second or slightly more.
I want to convert this file to DVD format, but of course, the dvd file will ALSO have the synch problem.
Can anybody please tell me how do I fix the source avi to sunch the last bit of the film?
It can be done with 2 Tools, Virtualdub for editting the Avi and Goldwave for editting the sound. There is a guide for editting with Vdub so I will only give the basic steps that I'd use.
First, cut and save the avi in 2 parts with Vdub, in-sync (part A) and out of sync (part B).
Extract a wav sound file from each part using either Vdub or Goldwave.
With Vdub, reload the wav file back into part A with the Wav Audio command, set audio and video to Direct Stream Copy and then save Avi.
With Goldwave, adjust the audio for part B, insert silence or cut out a portion as required. Save the altered wav file.
With Vdub, reload the wav file back into part B with the wav audio command, set audio and video to Direct Stream Copy and save Avi.
Load part A in Vdub and then add part B with the Append Avi command. Set audio and video to Direct Stream Copy and then Save Avi.
Other sound editers can be used instead of Goldwave, but that's what I'm familiar with.
Good Luck!"Art is making something out of nothing and selling it." - Frank Zappa
Thanks! Will give it a try today.
Added
THANKS! It worked perfectly!!!!
How to fix audio synch problem in AVI file
By vertical in forum Newbie / General discussionsReplies: 128Last Post: 2nd Sep 2011, 08:14 -
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 09:46 -
I lost audio in source and preview in all editing programs, how to fix??
By RogerTango in forum EditingReplies: 2Last Post: 9th Nov 2009, 20:43 -
How to synch audio cd source to existing dvd, properly (possible ?)
By bidelman in forum RestorationReplies: 5Last Post: 15th Oct 2009, 08:43 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00
Statistics
Newest guides
Latest tool updates
New media comments
