Im am ripping an svcd to Divx using Gordian Knot and the appz that come with it. The encoding worked perfectly and i have an AVI file, all i need to do is Mux the audio with it. This is where im not sure what to do, i tried using a program called AVI mux that came with gordian knot, i used the audio input as the mpeg audio file that was created when i frameserved with DVD2AVI, however, when encoding with gordian knot, an MV file approximately the same size as the audio file was created, the only thing is im not sure how to mux the AVI with the correct audio file (.MPA created with dvd2avi or the .MV file created using gordian knot?) Also, If the .MV file is an audio source created by gordian knot then what do i use to convert to a viable format. Any help would be great, thanx.
P.S. As i said i did attempt to mux the avi with the .mpa file, however, about 40 percent through the process an error occured, stating that a possible problem had to do with a frame header, or something to that effect.
Results 1 to 1 of 1
Need Help muxing to AVI
By ChrisDaMan in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 18:58 -
avi.NET sound problem in Interleaving AUDIO with VIDEO muxing
By ntiki in forum Video ConversionReplies: 4Last Post: 13th Mar 2010, 16:34 -
[AVI] Muxing aditional audio
By Wacken88 in forum LinuxReplies: 0Last Post: 25th Jun 2009, 09:56 -
h.264/AAC audio to AVI/MP3 muxing help
By Ryutso in forum Video ConversionReplies: 14Last Post: 8th Mar 2009, 12:13 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53
