  1. Hi,
    I just dontated to get the + version, my first attempt and I am allready having some problems. When I start the program I get the message:
    "Unable to check for update at this time.
    Make sure your internet connection is up."
    But I have a internet connection.
    By clicking OK the program is closed.
    So I can not use the Program.
    What can I do to work with my program?
    Thanks for help
    Ralle
  2. Member ChrissyBoy's Avatar
    There are two solutions to this issue. First you can download this file to your SVCD2DVDMPG+ folder and try starting the ptogram again. If that fails I'll send you another "fix".
    CB
  3. Hi,
    I have downloaded the file,and copy it into the program folder.
    But I get the error message.This was not the solution.
    Ralle
  4. Member ChrissyBoy's Avatar
    drop me an email & I'll send the other solution.
  1. SVCD2DVDMPG Problem
    By soma_dis in forum Newbie / General discussions
    Last Post: 6th May 2004, 03:36
  2. SVCD2DVDMPG problem
    By drewson99 in forum Video Conversion
    Last Post: 21st Jan 2004, 21:53
  3. svcd2dvdmpg problem
    By gsand in forum SVCD2DVD & VOB2MPG
    Last Post: 22nd Aug 2003, 07:40
  4. SVCD2DVDMPG+ problem with ordering files
    By snek11 in forum Authoring (DVD)
    Last Post: 30th Jul 2003, 01:22
  5. Problem with svcd2dvdmpg+
    By in forum SVCD2DVD & VOB2MPG
    Last Post: 8th Jun 2003, 23:35
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
