VideoHelp.com Forum
Thread: DVD rips
  1. I am using (dvd to svcd) to rip my dvds, but some dvds i have 2 films on them, how do I get it to rip both films, as it only rips the first 1, and cant get it to do the other 1, thanx in advance for any help,
    SATAN
  2. You simply need to manually select the second movie from your DVD, which i'm guessing would be the other longest section on the DVD.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. There is no other bigger file, its weird cause, half the first movie and half the second movie share vob 2, when (dvd to svcd) is running it does all vobs but only rips the first movie, how can that be if the end of one movie and the beginning of the other movie share a vob file, thanx in advance for any help....
    SATAN
  4. I'm not familiar with DVD2SVCD, have you tried using Smart Ripper or DVD Decrypter instead ?
    Best Regards,
    Sefy Levy,
  5. Ok guys, I think iv'e worked it out, had to select movie length, as there is two different ones if there is two movies on the dvd, as (dvd to svcd) alway only rips the one that runs the longest, so iv'e read somewhere, will let you all know if it works, thanx again for your help....
    SATAN
  6. Hope everything works out!
    Best Regards,
    Sefy Levy,
  1. Are dvd rips RBG or YUV?
    By dioxholster in forum Newbie / General discussions
    Last Post: 23rd Apr 2012, 06:14
  2. DVD and Blu-Ray rips
    By ldoodle in forum Blu-ray Ripping
    Last Post: 22nd Sep 2009, 22:11
  3. DVD Rips Taking Up Too Much Space
    By vidvidhh in forum Newbie / General discussions
    Last Post: 29th Jun 2009, 01:38
  4. Clearest DVD Rips
    By dudeman316 in forum DVD Ripping
    Last Post: 18th May 2009, 08:33
  5. DVD RIPS (non copyrighted) for educational use...
    By Spooky_uk in forum Newbie / General discussions
    Last Post: 30th May 2007, 18:33
