VideoHelp.com Forum
  1. Example: Elementary video and audio streams already encoded.
    Tools Tab:
    In previous versions (well, v0.0.6) you would select the post-processing actions and then select author and/or mux as and then hit Go!
    Now, you select your post-processing and then hit either Mux or Author?
    Or just Author and it knows to Mux?
    I'm afraid the interface is a little confusing as to how to accomplish a Mux and Author (or any other combination).
    Either a slightly expanded explanation or a more clear interface.
    I like the previous interface but the Go was confusing. Perhaps a Process button under the Fix button?
    Or is it just me?
  2. Originally Posted by digitaldave
    Mux will both mux and author (with the enabled author options, so if you disable all, it will only mux).
    Author will only author.
  3. While I understand the concept (after trying it) is there a way to clarify this small point in the manual?
    I believe in the previous version that even if you selected one of the authoring option but did not select Author and Split it would not when you hit Go. Is that correct?
    Great job on everything!
  4. Sure, I will add more detail in the online manual about this.
  1. Computer interface for Control-M?
    By bizzybody in forum Capturing
    Last Post: 7th Apr 2009, 23:56
  2. hi8 TO DVD VIA i.link interface
    By ACKEE in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 30th Oct 2008, 08:11
  3. Home Entertainment Interface
    By bmorgen in forum Media Center PC / MediaCenters
    Last Post: 1st Oct 2008, 22:31
  4. How to interface with DirectX ?
    By squadjot in forum Programming
    Last Post: 11th Apr 2008, 22:52
  5. Video and interface problems
    By dfgh11 in forum Media Center PC / MediaCenters
    Last Post: 25th Jul 2007, 20:15
