VideoHelp.com Forum
  1. http://www.2shareit.com
    Convert an avi file or Merge some avi files to VCD DVD SVCD format.
    Support avi to vcd dvd svcd with NTSC/PAL setting option.
    Support avi with DivX/XviD avi format.
    Support MPEG1, MPEG2, MPEG4 video format.
    Support MPEG layer1, layer2, layer3 audio format.
    "Split function" to split big mpeg file to several small segment, so that it can be fit into cd-r.
    Input/Output preview.
    Fill in / Customize options for cropping output video.
    Support output effect.
    Registered users can receive free upgrades and support for life.
    Support Input/Output list and other options saving automatically, finishing it anytime. Cool and easy to use Interface!
  2. Please give some comments...
  3. I'll have to give it a try. Do you know if you can choose or adjust bitrates (CBR/VBR, DVD bitrate of 6000, etc.) for the output? I'm just wondering how customizable the application is? Sounds like a nice product.
    blade29
  4. Member tipstir's Avatar
    The Aare AVI to VCD, DVD, SVCD, does work very well, but the split a file features doesn't work at all, otherwise it does all the work and correct input and output of you AVI files conversions easy, there is also a fill-in so you can expand the default image size for VCD, DVD and SVCD. What I have seen so far on the output looks very good, even better than TMPGEnc and MainConcept MPEG Encoder, there is one from AVSMedia Video Converter, hasn't won me over yet, still testing that one out.
    Give Aare AVI Converter a try... Make your day go quickier when converting...
  5. i tried this product tmpgenc has way more features plus its free and it said it would take three days to convert 1.3gig file to svcd while tmpgenc only takes 15 hours
  1. Replies: 8
    Last Post: 8th May 2010, 17:01
  2. Can't convert avi to vcd, svcd etc...Failed Message
    By shankbone in forum ffmpegX general discussion
    Last Post: 10th Oct 2009, 01:12
  3. How to convert VCD to Xvid (avi)
    By nalika in forum Newbie / General discussions
    Last Post: 22nd Jan 2008, 16:51
  4. I have converted avi to vcd and svcd im looking to convert avi to dvd
    By dbztoolkit in forum Newbie / General discussions
    Last Post: 11th Jun 2007, 12:14
  5. Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
    By scratchman in forum User guides
    Last Post: 4th Jun 2007, 01:36
