VideoHelp.com Forum
Results 1 to 9 of 9
    Hi,
    I'm a newbie, I tried searching first but sorry if this was already posted before.
    I like using graphedit for encoding, converting, and sometime just playing files because i like to see what filters it uses and how it works. I have a bunch of audio codecs, Including Mpeg Layer 3, DivX Audio, Lame MP3, and a couple more.
    Now with virtual dub i can see the list of audio codecs, and by going into my control panel\Sound and multimedia devices, and looking at the properties of "audio codecs" i can see all my codecs, I also installed all my codecs onto my laptop.
    Now here is the problem, when i use graphedit I select insert filters, and i go to audio compressors, none of my codecs are there. Only 3 are listed "Vorbis Compressor" "Vorbis Encoder" and "WMAudio Encoder DMO".
    I don't see my MP3, DivX, or anything else. Now on the other hand when i look at my video compressors i see all my video codecs. Also, on my laptop I can see all my audio codecs with graphedit, just not here. I did notice that all the audio compressors (except for the ones i could see) were assoiciated with quartz.dll when i saw them on my laptop. But I can see other filters from quartz.dll, quatz.dll is a directX file. Please Help Me.
    Is this a problem with my codecs? directshow? graphedit? Or what?
    Help would really be appreciated.
    -jc511
  2. did you run the Register.bat ?
    regsvr32 dump.ax /s
    regsvr32 wavdest.ax /s
    regsvr32 mpeg2parser.ax /s
    regsvr32 multiple_mpeg2_source.ax /s
    regsvr32 lame_dshow.ax /s
    regsvr32 iviaudio.ax /s
    see the readme file that comes with it
    Yes, i ran it before and i just ran it again. no change The problem is that my audio compressors section is just about empty. Where as on my laptop, where i installed the same codecs, i see them. I did notice that all the missing ones were assoiciated with "quartz.dll" on my laptop. I didn't even know they weren't there until i read the ogm to vcd guide and it said to insert the MPEG Layer 3 audio compressor filter.
    thanks for responding,
    -jc511
  4. I put it on my system about 2 years ago So forgot if anything else was needed. Try adding it to your path ? do you have Win 2000 on both machines ?
    add it to my path?
    Actually my laptop has windows xp. also it does have directx 8.1 where as this computer has 9.0. could that be the problem? hmmm... i don't know. it worked before... in fact i've used it before and had the codecs there. it was recently when i had sent my laptop service because it had a problem and was under warenty. when i got it back it was wiped out, so i was reinstalling everything. thats when i decided to upgrade the programs on this computer too. i upgraded virtual dub, tmpgenc, graphedit, divx, and the rest of my codecs (mpeg layer 3, lame mp3, and more). Maybe that will explain it.
    thanks for trying to help,
    -jc511
    argh.. this is weird...
    i uninstalled and reinstalled my radium mp3 and lame mp3 codecs, now in graphedit all my audio codecs/compressors are there except for those 2.
    I don't understand this at all...
    anybody know whats going on?
    -jc511
    Oh, wait a second.... I REMEMBER NOW!! ok i know when this started and maybe it will help solve this problem. I use to have the Nimo codec pack, and it had all my audio codecs in it. But a number of people told me it was bad, and had a lot of problems with compatibility, eventually someone blamed it for making me not able to play some ogm files i donwloaded and at that point i uninstalled it and went on a giant egg hunt downloading and installing the codecs i had lost. Thats when this whole thing started, and i was missing my audio codecs in graphedit, now a bunch of them just magically came back except for the mpeg layer-3 and lame mp3.
    I hope this helps
    -jc511
    p.s. sorry for the multiple posts
    ................anybody?
    can anybody help me?
  1. Graphedit filter chain with ac3 audio
    By sambat in forum Video Conversion
    Last Post: 19th Jun 2011, 12:18
  2. Replies: 0
    Last Post: 23rd Jul 2010, 20:38
  3. Replies: 0
    Last Post: 21st Dec 2008, 12:41
  4. codec - Graphedit - problem
    By joepic in forum Video Conversion
    Last Post: 17th Jun 2008, 08:11
  5. audio codecs problem...
    By cwb in forum Linux
    Last Post: 13th Jan 2008, 15:12
