If I want to run SDEpatcher separately is the syntax:
SDEpatch <svcdfile.m2v> NTSC
Can the target file be a mpeg 2 video stream or does it have to be a muxed audio/video mpeg 2 file?
Thread: SDEPatcher.exe Syntax
Couple of more questions regarding sdepatcher..
When running on some m2v files I got the message:
Does the patcher just check the existence of SDE headers or does it also check to make sure the SDE headers are correct (Thus eliminating the need for "Fix12c.exe - MPEG2 SDE patch" completely)?Code:Badgerware SDE Patcher (SVCD) v1.0 Standard: NTSC Working: --- No need to patch
Also when run agains another .m2v svcd file I received the following error message towards the end of the operation:
But the file it created seems complete and undamaged, should I worry about this?Code:Arithmetic operation resulted in an overflow.
Thanks for any input you can provide.
Syntax is as you have deduced. (how did you do that?)
First param is a MPEG2 Video Stream.
Currently it skips if there is SDE info (i.e doesn't enforce the correctness of the existing SDE)
"Arithmetic operation resulted in an overflow. " as this happens towards the end of the operation i suspect it is ok. However if anyone can send me the complete file where this happens I'll get to the bottom of it.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
talynone, you can use restream to remove sde so sdepatcher will add one. only works on elementary vid files though. Also, adding the sdepatcher to complete vob doesn't make my dvdplayer very happy. Which rules out authoring with menus in dvdlab, and sdepatching after. (patching before gets cancelled out upon dvdlab authoring I believe.) CB, any light you could shed here would be cool.
AviSynth Syntax/Grammar
By sambat in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2012, 18:21 -
X264 CLI Syntax Help
By Eva-Unit01 in forum DVD RippingReplies: 9Last Post: 2nd Dec 2011, 17:42 -
Syntax error
By zecamigo in forum ffmpegX general discussionReplies: 4Last Post: 12th Mar 2009, 11:16 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42 -
Syntax bug in SVCD2DVD
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Nov 2007, 11:14
Statistics
Newest guides
Latest tool updates
New media comments
