Since purchasing my E30 recently I have looked on Panasonic's Australian website recently to check which DVD-RAM discs are compatible with my recorder. When I follow the links I get to http://www.panasonic.com.au/catalogue/list.cfm?cat=5_1
which shows that I can use:
3 pack 120 min DVD-Ram Discs (Model: LM-AF120E3) 4.7gb and
240 min DVD-Ram Disc (Model: LM-AD240E) 9.4gb
However, I have seen elsewhere (and even on Panasonic's site) that there are also some other discs that are supposedly for data ie. - as per Panasonic's site again ( http://www.panasonic.com.au/catalogue/list.cfm?cat=43_6) "DVD Media Preformatted for Data" - these include
9.4 GB DVD-RAM REM. CARTRIDGE (Model: LM-HB94F)
4.7 GB DVD-RAM REM. CARTRIDGE (Model: LM-HB47F)
4.7 GB DVD-RAM DISK,Jewel Case (Model: LM-HC47F)
My question is this - can I use these "data DVD's" for day to day recording of TV programs on my E30 or are they only usable in PC based recorders? The data DVDs are significantly cheaper than the other (non-data??) ones here in Australia so I would love to use them if I can.
I suggest you check out this website. They sell dvd-ram media for about $8 for double sided media 9.4 gig(Optodisc). I have used it in my hs2 and e20 withany problems. they ship internationally:
www.netsoftmedia.com.
Check out www.newegg.com they are based in the USA and might sell internationally They have panasonic media for $11(9.4 gig). They sell optodisc media for as low as $5.60 (9.4 gig) in quantity purchases.
www.rima.com sometimes ships internationally. They have the dvd ram for as low as $7.50 (9.4 gig) depending on quality ordered.
Optodisc media is panasonic certified and their media in cartridges has a warranty.
The only difference in the video and data media is that the video media comes preformatted for the Hs2. You will have to format the data dvd-ram disks to use them in the Hs2. It takes 30 secs to a minute to do it and you can do it on the Hs2( very simple).
Panasonic DMR-EH50 and Pan. DVD-RAM disks inconsistent
By rehoboth in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2012, 21:50 -
panasonic dmr E30 compatibility
By jimakros in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Dec 2008, 12:19 -
Panasonic DMR-ES35 fails to read discs
By lilblu in forum DVD & Blu-ray RecordersReplies: 7Last Post: 17th Jul 2008, 05:42 -
DVD-RAM discs causing Panasonic DMR-ES10 recorder to 'fall-over'.
By dreamcloud9 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 6th Mar 2008, 23:24 -
DVD-R discs work and then fail in Panasonic DMR E85H
By herefordjw in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Aug 2007, 11:09
Statistics
Newest guides
Latest tool updates
New media comments
