I've read numerous posts about the Macrovision "white bar" syndrome here. It seems that bar is constant throughout the movie in these posts. However, mine is not. It only shows up once in a blue moon, maybe 4 or 5 times per hour of video. It seems to always pop up during an abrupt transition in the movie and remains until the next transition. I also experimented with rewinding or fast forward while previewing, and the bar will usually pop up and not disapper until I play again and it hits a transition.
I have installed TVTool and turned Macrovision off. This does not solve the problem. Before I try stepping back to WDM 1.08 (I'm using Asus v8200 T2), does anyone have any suggestions as to what else I can do? Every time I try screwing with any kind of driver for the Asus card, I have nothing but problems. Asus motherboards seem to have similar driver issues as well. Bout sick of Asus, even though they provide lots of features, speed, etc. Anyway, I digress.
Todd
Oh, I failed to mention. This happens during the previews too. I was under the impression that only the movie was encoded with Macrovision.
No I think it's on the whole tape.
I have this.
http://www.videoguys.com/sima.htm#sedcm
It works fine. Except when the VHS is damaged or very worn. Then the Macro still shines through.
NOT endorsing the site. Did NOT buy it there.Don't give in to DVD2ONE, that leads to the dark side.
isnt there any sofware programs that can turn the macrovision signal of or do i have to invest in one of these boxes to make a safety copy of my vhs tapes
There are some patches that tell the capture card to not read the macro. I only believe one type of card has this patch. I don't remember which it is.
Intermittent Ghosting
By koberulz in forum RestorationReplies: 1Last Post: 27th Feb 2012, 10:14 -
Intermittent sound on mini-DV capture
By adamj_ut in forum CapturingReplies: 5Last Post: 17th Nov 2009, 17:47 -
Easycap Video Capture Adapter VHS to DVD Macrovision Removal.
By Teac23 in forum CapturingReplies: 5Last Post: 18th Aug 2009, 09:48 -
Intermittent Jerky Playback Question
By Maikeru-sama in forum Video ConversionReplies: 11Last Post: 12th Oct 2007, 07:30 -
Capture card w/scriptable commandline app & macrovision warning?
By miamicanes in forum CapturingReplies: 2Last Post: 9th Sep 2007, 11:31
