VideoHelp.com Forum
  1. I have made hundreds of .d2v files with DVD2AVI, put them in TMPGEnc, and had them work just fine. I did the same thing as before, except this time I deleted all the other files of the DVD, excluding the .d2v and .wav files. I put the .d2v file in the TMPGEnc and it took a while before a message came up stating it did not support that file??? What does that mean, what do I have to do to make it work?
    Thanks for the help.
    If everything is infinite then nothing is definite.
    You probably changed something or unregistered the VFAPI option by accident.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  3. Did you keep the video-stream related to the d2v-project file? The d2v file is really nothing but a project definition with a link to the original video-stream.
    I don't know if that could cause TMPGEnc to suddenly forget its support for d2v-files.
    /C
  1. MKV file not supported on Cello 3D TV
    By sjpriest79 in forum Newbie / General discussions
    Last Post: 24th Nov 2011, 17:39
  2. VirtualDub D2V file error
    By Dr.Who in forum Video Streaming
    Last Post: 17th Dec 2010, 14:23
  3. Break! File not supported!
    By kramboa in forum DVD Ripping
    Last Post: 7th Nov 2009, 08:31
  4. AVI File Not Supported by TMPEGnc?
    By The Monkees in forum Video Conversion
    Last Post: 3rd Feb 2008, 18:26
  5. Is there a list of all supported files supported by svcd2dvd ?
    By geek2330 in forum SVCD2DVD & VOB2MPG
    Last Post: 19th Oct 2007, 11:07
