VideoHelp.com Forum
  1. Hi All,
    I have a PB G4 1GHZ 512MB RAM w/ Superdrive, and am getting in to DVD burning.
    I'm just wondering if its wise to keep using your computer while Toast is burning your DVD, even if Buffer Underrun protection is on.
    ATM I just leave it alone (actually I burn on my gf's PB & keep using mine) as I don't want to make a coaster - am I being stupid?
    Cheers!
  2. Member galactica's Avatar
    To be honest, its really up to you!
    Yes, the less your comptuer is processing while you are burning a dvd, the more likely you are to get a perfect dvd.
    To that point however, I typically chat on iChat, surf the web and read email while burning dvd's
    even with a 2x burn its still a good 20-30 min! and thats precious computer time im loosing if i just let it go alone!
    I have never gotten an error to date becaue of me being active while a burn is in progress.
    Now, I wouldn't do any intensive apps, like dvd2one or ffmpegx conversion that hogs processor, but simple every day apps and tasks should be no problem.
    NOTE: This is for his computer at 1gz. If you had say a 500mhz G3 I would recommend waiting and let the burn contiune with as little background processing as possible! My old comptuer had problems with just cd burning if other things were going at the same time!
  3. No Longer Mod tgpo's Avatar
    I almost always have something else going on while I'm burning. So far it hasn't affected any of my burns, so I'd say that as long as you have the memory to do it, it should be fine.
  4. No Longer Mod tgpo's Avatar
    BTW, I have a 450mhz G4 at it mutitasks just fine.
    In general, don't multi-task too much. The most I ever do is play cards or read e-mail while burning - you know, errand stuff and mind killers. If you try to burn AND render another video or load Photoshop, well then, that's when you're asking for trouble. This applies to all systems: Mac, PC, Linux, Sun, etc.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  6. Cool - thanks for the replies.
    Looks like I'll just surf the net or something while the burn is going. Good excuse not to keep working on GoLive, Illustrator & Photoshop
    Cheers.
  7. I've had problems with coasters when i use really intensive apps, such as I'll be unraring 3 seperate .rarred movies in 3 different terminals, encoding something with ffmpeg and trying to rip something with the always freezing gnuvcdtools. Then I'll get a buff underrun in one of those temporary memory clogs where the memory monitor gets to 100 percent and hovers there....but when i just do normal stuff, no problems
    Jeff
    THUS the basis of roxio's BUFF UNDERRUN protection (BURN), however, I must say that they can never really fully BURN proof dvd-r drives from people as stupid as myself
  1. Replies: 2
    Last Post: 29th Jan 2012, 12:42
  2. DVD Lab Pro Error: "Read data size is over the buffer limit"
    By Motinha in forum Newbie / General discussions
    Last Post: 29th Oct 2010, 02:49
  3. Replies: 5
    Last Post: 6th Aug 2010, 05:08
  4. Stability and multitasking in Linux
    By Haopengyou in forum Linux
    Last Post: 6th Nov 2009, 18:52
  5. Replies: 7
    Last Post: 31st Aug 2007, 22:55
