VideoHelp.com Forum
  1. I own a Zenith DVB312 DVD Player and I have searched high and low, near and far for the Region Free hack for it. My brother brought home some Italian DVD's for my parents but they are set to play in that region. Can anyone please help me find any type of region free hack that may work on my dvd player??? (i've tried the program "5" program "5" thing, no luck)
    Thank You,
    RS
    It may not have one. One of my players (Toshiba 2800) has no hacks.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
    Hi,
    Try this:
    1) Power up with NO cd in the drive
    2) Press PAUSE
    3) Press 1472
    4) At the EEPROM screen write down the code for backup (Mine was 55 53 00 45 14 55 64 FF)
    **Use the left and right arrows on the remote to move
    **Press the number keys on the remote for number entry
    **Press and hold numbers 1 thru 6 for letter entry
    5a)If you want to enable VCD AND disable Macrovision:
    Enter: 55 53 00 47 14 55 FE FF
    OR: 55 53 00 46 14 55 FE FF
    5b)If you want to enable VCD without messing with Macrovision:
    Enter: 55 53 00 47 14 55 64 FF
    OR: 55 53 00 46 14 55 64 FF
    6) Press PAUSE to exit the EEPROM screen
    7) Press POWER to turn the unit off
    8) Press POWER to turn the unit on
    9) Insert VCD disk
    10)Press PLAY when ready
    This should also enable SVCD playback
    Greetz,
    pSyChO dAd
    The difference between genius and insanity is only measured by success !
