VideoHelp.com Forum
  1. Hi... I always understood that when you convert a DivX movie to VCD format it will get larger in size. But, I have a DivX movie (DivX 5.0.3 Codec / 704 x 432 format) of 714 MB and when I convert it to VCD with TMPGEnc using the VCD template I get an MPG of just 496 MB.
    Also the DivX is of a superb quality, almost DVD, but the MPG is much less quality and has quiet a lot of blockiness. Am I doing something wrong and is there a way to get a better quality MPG...? Thanx a lot for your help cause I have been trying everything....
    check your settings in tmpgenc you dont hafta use a template to make your vcd you can play around with the settings till you find a combat ion the meets your needs
    cancel the wizard then then click load then then the extra folder -> unlock.mcf this will unlock all the settings
    those are a few settings to getting started on make an xvcd after you change your setting you can save them by clicking 'save' name it something like XVCD then you can select it from the wizard everytime it loads.... it will take to cd's to for 1 movie you can use the source range to split the movie in half
  1. Replies: 2
    Last Post: 19th Jul 2011, 02:35
  2. Converting videos -> smaller file size
    By karib in forum Video Conversion
    Last Post: 10th Dec 2010, 14:31
  3. Smaller file size after Video Capture (help)
    By convoy71 in forum Capturing
    Last Post: 4th Apr 2009, 17:05
  4. Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
    By GrayStrickland in forum Video Conversion
    Last Post: 18th Oct 2008, 17:06
  5. XviD and DivX file size
    By timmer545 in forum Video Conversion
    Last Post: 9th Nov 2007, 15:30
